rdawsoniii
Apr 10, 2018Star
I'VE JUST ABOUT HAD IT....
I've had the RBK40 for about 10 days and have yet to go 24 hours without problems. Constant disconnects. I've reset to factory default 3 times. I've updated to the newest firmware. Power cycled. ...
rdawsoniii
Apr 10, 2018Star
Yes, I've set up from scratch (3 times!) since the FW update. Satellite is between 30-40 feet. Noted items disabled.
Square footage is around 1300.
I did change the 2.4 channel to 11 once, but it made things even worse. I am going to try channel 1. Not sure how to know which 5g channel is "unused". Another poster suggested ch48. Will try tonight.
I really hope this works, because, when it works, the Orbi is great. I just can't be mucking with this multiple times a day.
Apr 10, 2018Guru - Experienced User
With a 1300sq ft home, you might not need a satallite. The router alone can cover this kind of size home if placed centerally.
Also disable Daisy Chain, MIMO and Fast Roaming to test.
AP mode suggestion:
https://community.netgear.com/t5/Orbi/Issue-with-2-1-3-4-in-AP-mode/m-p/1546189
rdawsoniii wrote:Yes, I've set up from scratch (3 times!) since the FW update. Satellite is between 30-40 feet. Noted items disabled.
- WizecApr 10, 2018ApprenticeI’ve been doing some long-haul testing of different settings, and the only setting change that has actually helped matters for me was disabling “Enable 20/40 MHz Coexistence”, as suggested by DarrenM
With that setting enabled, I get multiple disconnects per day. With that setting disabled, I’ve only had one disconnect in the last two weeks.
YMMV- FURRYe38Apr 10, 2018Guru - Experienced User
This would be a good a suggestion as well. This maybe needed if you have other neighboring wifi signals near by however.
Thanks for letting us know.
YMMV
