djc6's avatar
djc6
Luminary
Jan 13, 2017
Jitter issues via Orbi vs direct to modem
I recently replaced my Arris SB6190 modem with a Netgear CM600 due to the well publicized issues with jitter/latency on Intel's Puma 6 chipset that the SB6190 uses.   One of the tools used to help ...
  • djc6's avatar
    Jan 25, 2017
    So inexplicably, since the morning of Monday, January 22nd I've run multiple jitter tests using dslreports.com's tools and no jitter issues are observed.  The following test was done via Wi-Fi connected to Orbi on a Mid-2012 retina macbook pro running Sierra.
    great jitter test
    So I have to imagine whatever was going on was unrelated to Orbi or my Netgear CM600 cable modem.  Firmware versions same on both devices since my original post, and I've changed nothing on configuration.  Seeing these results across multiple macs behind my Orbi router.
