djc6
Jan 13, 2017Luminary
Jitter issues via Orbi vs direct to modem
I recently replaced my Arris SB6190 modem with a Netgear CM600 due to the well publicized issues with jitter/latency on Intel's Puma 6 chipset that the SB6190 uses. One of the tools used to help ...
- Jan 25, 2017
So inexplicably, since the morning of Monday, January 22nd I've run multiple jitter tests using dslreports.com's tools and no jitter issues are observed. The following test was done via Wi-Fi connected to Orbi on a Mid-2012 retina macbook pro running Sierra.
So I have to imagine whatever was going on was unrelated to Orbi or my Netgear CM600 cable modem. Firmware versions same on both devices since my original post, and I've changed nothing on configuration. Seeing these results across multiple macs behind my Orbi router.
MarkC1024
Jan 14, 2017Luminary
I too have switched from the SB6190 to the CM600. However, I'm not having any ping issues with this configuration. Below is what is reflected when connected from my iMac via WiFi (older so not using 802.11ac)
rhester72
Jan 16, 2017Virtuoso
From what I could tell from here (New Jersey, USA), your results with this test are -highly- dependent on your location and ISP.
A region-served service like Google is a far more accurate test - if you mtr to www.google.com for, say, 250 packets, you should get a much better idea of where you're at in terms of latency than with this test. (And, for the record, Orbi produces -excellent- results in that department - far lower than Google OnHub or eero, based on my own testing, even over wifi).
Rodney
