DaveAnderson
Mar 16, 2021Guide
Joining the crowd of RBR50/RBS50 which broke after firmware upgrade
I upgraded the firmware on my router around a day ago, and have repeatedly had the internet cut out. Wifi would keep functioning (you could be connected), but there was no internet behind the wifi. ...
- Mar 17, 2021
I've now gone around 24 hours without the internet cutting out (previously it was going out every few hours, and 100% was out when I'd wake up in the morning). I'm going to call this a "fix" until I learn otherwise.
Downgraded both the router and satellite to 2.3.5.30.https://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.3.5.30.zip
https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.3.5.30.zip
For those 2 files: You install the RBR firmware on the router, and the RBS firmware on the satellite.
You go to the IP address of the router to update it's firmware, then look at devices list, find the IP address of the satellite(s), go to that ip address in your browser (log in), and update the firmware on the satellite.
Easy peasy for even non-technical people.
Mar 17, 2021Guru - Experienced User
Also power OFF the ISP modem and RBR for 30 seconds then back ON after you make the NTP change.
Hollywired wrote:Hello, Community. Please excuse me if I make any errors; this is my first post.
When I woke up on Monday, everything on WiFi in my house was still connected to the Orbi locally, but anything that needed internet said none was avaialble. My modem, supplied by my internet company, is working fine. A reboot of the Orbi fixed the problem, but it recurred at around 5:00 PM that day, then again when I woke up on Tuesday, then around 1:00 PM on Tuesday, and again when I woke up this morning (Wednesday). Each time, a reboot of Orbi easily solves the issue until the next time.
I haven't seen any solutions that I understand in the forums. The previous poster suggested contacting Netgear Support. I assume that can only be done through the paid support option at GearHead, if my Orbi is out of warranty? Thanks so much for any insights. Have a great day.
Hollywired
Mar 18, 2021Tutor
Hello, Community. Just checking back to let you know that, after I had one more outage yesterday around 4:00 PM, I following the insturctions:
F) Modify NTP Settings:
1-Uncheck the "Automatically adjust for daylight savings time"
2-Change your timezone "east" one hour to accommodate turning off the auto DST.
and
This morning, I woke up and all my devices were still able to access the internet. Thank you so miuch for being so helpful!! Have a great day.
- vajimMar 18, 2021Master
Hollywired wrote:Hello, Community. Just checking back to let you know that, after I had one more outage yesterday around 4:00 PM, I following the insturctions:
2-Change your timezone "east" one hour to accommodate turning off the auto DST.and
Thanks for the update. Please keep in mind that IF NG fixes this in the next firmware update which you accept, you may have to go back and switch these settings back or reinstall your saved settings.
- skitzrvMar 20, 2021Initiate
I executed your workaround along with adding "Change the NTP server to 1.pool.ntp.org"
so far so good
- FURRYe38Mar 20, 2021Guru - Experienced User
What FW version are you using?
skitzrv wrote:I executed your workaround along with adding "Change the NTP server to 1.pool.ntp.org"
so far so good
- skitzrvMar 22, 2021Initiate
V2.7.2.104
No problems since I executed the DL savings workaround
- billaschMar 21, 2021Guide
BTW, this worked for me. Not one problem since I turned off the Daylight Saving adjustment. Thanks!
- HollywiredMar 22, 2021Tutor
Hello, Everyone.
A follow up to this. I was able to change the DST and time zone settings back to correct and I have had stable connections since by turning OFF the Traffic Meter feature in the app.
I am running firmware version 2.7.2.104 on my RBR50.
Thank you.
- vajimMar 22, 2021Master
Hollywired wrote:Hello, Everyone.
Thank you.
band-aid
