DaveAnderson
Mar 16, 2021Guide
Joining the crowd of RBR50/RBS50 which broke after firmware upgrade
I upgraded the firmware on my router around a day ago, and have repeatedly had the internet cut out. Wifi would keep functioning (you could be connected), but there was no internet behind the wifi. ...
- Mar 17, 2021
I've now gone around 24 hours without the internet cutting out (previously it was going out every few hours, and 100% was out when I'd wake up in the morning). I'm going to call this a "fix" until I learn otherwise.
Downgraded both the router and satellite to 2.3.5.30.https://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.3.5.30.zip
https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.3.5.30.zip
For those 2 files: You install the RBR firmware on the router, and the RBS firmware on the satellite.
You go to the IP address of the router to update it's firmware, then look at devices list, find the IP address of the satellite(s), go to that ip address in your browser (log in), and update the firmware on the satellite.
Easy peasy for even non-technical people.
DaveAnderson
Mar 17, 2021Guide
SethPen
Mar 18, 2021Initiate
Follow this procedure to correct , if you are having this issue. I was able to get a stable network after downgrading.
