DaveAnderson
Mar 16, 2021Guide
Joining the crowd of RBR50/RBS50 which broke after firmware upgrade
I upgraded the firmware on my router around a day ago, and have repeatedly had the internet cut out. Wifi would keep functioning (you could be connected), but there was no internet behind the wifi. ...
- Mar 17, 2021
I've now gone around 24 hours without the internet cutting out (previously it was going out every few hours, and 100% was out when I'd wake up in the morning). I'm going to call this a "fix" until I learn otherwise.
Downgraded both the router and satellite to 2.3.5.30.https://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V2.3.5.30.zip
https://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V2.3.5.30.zip
For those 2 files: You install the RBR firmware on the router, and the RBS firmware on the satellite.
You go to the IP address of the router to update it's firmware, then look at devices list, find the IP address of the satellite(s), go to that ip address in your browser (log in), and update the firmware on the satellite.
Easy peasy for even non-technical people.
ChristineT
Mar 24, 2021NETGEAR Employee Retired
Hello Orbi Community!
There are a few threads about recent issues with Orbi. As a result of working with a few of you, we've discovered that some of the issues have been caused as a result of the Day Light Savings event when the traffic meter is enabled. We are testing a trial firmware at this time and hope to have it released in the very near future. However, we recommend disabling the traffic meter as a workaround until the issue is confirmed to be resolved in this new firmware.
Please let me know if you still experience issues after disabling the traffic meter.
Kind Regards,
Christine
ShaneAN
Apr 01, 2021Tutor
I have an issue -- PHONE SUPPORT. If you keep on pushing out firmware that breaks our previously FINE working router setups -- TAKE SUPPORT CALLS and don't try to extort people for 100 dollars to resolve the issue that you've caused. It's absolutely ridiculous that you offer a paltry 3 months of customer support and then break our setups with buggy firmware updates -- and then won't help us fix what you broke.
I will NEVER buy a netgear product again.
