banderson832
Sep 02, 2020Follower
Just bought a new ORBI, will not connect..anyone else having these issues..please help
My Orbi will not connect to the internet.
- tucsonticoVirtuoso
In order to help you there are a few questions that need answers:
1) What type of internet connection do you have, e.g., cable, fiber optic, or other?
2) What brand and model of modem do you have?
3) Who is your internet service provider?
4) Can you describe your connection attempts so far?
Please be specific in how you've tried to configure your ORBI, i.e., what cables are plugged in where, etc. for the ORBI, your modem and any distribution switches.
There are plenty of experts on this forum who will chime in soon to help if you post this info.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Modems with built in routers and wifi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
banderson832 wrote:My Orbi will not connect to the internet.
