dpl7
Jun 19, 2019Follower
just did an update RBR/RBS50. Everything works except my iphone 10
My RBR/RBS50 was working beautifully for the past 6 months. I purchased an additional RBS20, connected it and was prompted for an update. Everything in my house has had a strong connection since the ...
Jun 20, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
dpl7 wrote:My RBR/RBS50 was working beautifully for the past 6 months. I purchased an additional RBS20, connected it and was prompted for an update. Everything in my house has had a strong connection since the update, but my iphone 10 cant keep a connection. My gf's iphone 6 works great and other apple items work, but my phone (which is the main hub for the app) is having major issues. I've been able to run 1 connection speed in the app out of about 12 tries, all other tries gave me a connection error. I've tried rebooting the router, tried doing a new setup and tried 3 times to reboot the modem. Please help!
