Alkaladar
Oct 09, 2021Aspirant
Just got RBK50. Devices are refusing to connect to satellite and vice versa
So i got the RBK50 today and set it up. Signal strength is good. They are about 10-13m/35-40ft away from each other separated by 3 walls. I go to the back of the house with he satellite being th...
Oct 09, 2021Guru - Experienced User
What firmware are they on?
if you disconnect your device from the wifi and let it reconnect, does it connect to the satellite?
If you hardwire into a satellite, does it work?
Might also get better help in the orbi forum versus the standard nighthawk forum.
Alkaladar
"What firmware are they on?"
1V2.7.3.22
"if you disconnect your device from the wifi and let it reconnect, does it connect to the satellite?"
No
"If you hardwire into a satellite, does it work? "
I will have to try this in the morning. Otherwise I will wake m kids up.
"Might also get better help in the orbi forum versus the standard nighthawk forum."
Will do thanks.
