switters's avatar
switters
Apprentice
Dec 23, 2019
Just installed Orbi and having problems
I just bought an Orbi 6 (RBK852). I put my Xfinity XB6 router in Bridge Mode and deactivated the xFi Pods I had. I went through the setup process for the Orbit 6 and it seemed to work fine.
However, I'm having three issues.
1) When I click on "Device Manager" in the app, I get an error message: "Sorry, the action was failed. Please try again."
2) Our house is wired for ethernet with Cat-5e and we have gigabit service through Xfinity. Before installing the Orbi, I was getting ~920-940 Mbps download speeds via ethernet. (My desktop computer in my home office was connected to the ethernet wall outlet, and then I had an ethernet cable doing from the home termination hub directly to the Xfinity router.) However, after setting up Orbi and plugging the ethernet cable corresponding to my home office into one of the Orbi LAN ports, I am only getting about 80-100 Mbps.
3) I'm getting about 200-350 Mbps download speeds using WiFi with Orbi. I thought it would be higher with a gigabit connection?
Thanks.
