VMSguy
May 03, 2020Follower
Just one sites audio won't stream from Orbi
Orbi RBR50, streams everything except one site:
https://www.rte.ie/radio/radioplayer/html5/#/rnag
This a web player. It will not play on any device or PC.
It will not play on my iPhone, my iPad nor my personal PC.
All other streaming works, I have most, Amazon, Soundcloud,
Netflix, YouTubeTV, .... all work fine.
The RTE site does stream fine in AT&T LTE and any other wifi I am on.
I have pretty default set up, I don't have a double NAT issue.
Any help would be appreciated.
1 Reply
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
