Zoomey
Feb 02, 2020Aspirant
Just updated firmware RBR50
Just update firmware on a my RBR50 to 2.5.1.8 and now the wireless keeps dropping... any suggestions?
- Feb 03, 2020
Please give feedback to the questions presented as well:
Under Advanced Tab/Advanced Settings/Wireless Settings
Feb 02, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Been using v2.5.1.8 since it came out. System has been stable and solid for me.
