Comander69
Oct 26, 2021Aspirant
Kann der RBR50 V2 direkt an einem Glasfasermodem betrieben werden ?
Hallo, bei mir wurde Anfang der Woche ein Glasfaseranschluss von Eon Highspeed aufgeschaltet. Jetzt versuche ich schon einige Zeit erfolglos den RBR50 an ein Glasfasermodem von Eon anzubinden. (La...
Comander69
Sorry ,I didn`t saw that i was writing in the english forum... ;)
Hi there,
At the beginning of the week, a fiber optic connection from Eon Highspeed was activated for me. I have been trying to connect the RBR50 to a fiber optic modem from Eon for some time now, without success. (According to the description, the fiber optic modem already provides Ethernet). Is the connection even possible in this form? In other words: Can the Orbi be operated directly on a fiber optic modem? (purely technical) Or do I have to hang in between a Fritzbox, for example? I switched the Orbi to router operation, but the rest of the setup is not really clear to me. I would be grateful for any hints.
Oct 26, 2021Guru - Experienced User
You'll need to ask your ISP if you can connect a external router to there ONT. There maybe some specific configurations needed that they should know about.
Regarding modems and ONTs with built in routers.
if the ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
