Friendlyx
Jun 27, 2017Tutor
Keep Loosing Internet Connection with my Orbi
I recently bought an orbi from amazon and i love it because it reaches throughout my whole house unlike my old router. However, i have noticed that i have dropped internet connections at times. For e...
DBetts
Oct 29, 2017Guide
Same issue, have updated to the latest firmware, problem is getting worse, now drops internet connection 6-7 times per day.
If there is a fix, please get it out fast, this is really unacceptable.
DBetts
Oct 30, 2017Guide
I have updated the system to V2.0.0.74 no improvement. I have MU-MIMO and beamforming enabled but it is not random connected wireless devices dropping the internet connection, it is the base router and all devices lose connectivity simultaneously whether wired or otherwise. Have spoken to support, its like they don't listen, having me change channels on the wireless settings, umm sure, lets do that. End of tech support today was, must be my ISP, so had the ISP out, all tests clean. Subsequently connected my old Linksys router and voila, stable connection. Netgear, time to acknowledge you have a problem...
- Streak2Oct 30, 2017Master
As a final attempt, try and do a factory reset now that you have the latest firmware. Also, what's the IP range of your ISP router and what's the IP range of the Orbi?
- DBettsNov 01, 2017Guide
Orbi "Outrageously Rediculous Blatantly Ineffectual" . Both the equipment and the support. They know they have a problem, multiple firmware updates, no resolution. Since updating to 74, my internet interuptions are at 10-12 per day, typically 6-8 minutes. Every support call arrives quickly at, "put a pin in the little hole". I am at approximately 10 factory resets, reboots ad nauseum. They know they have a problem, yet they tell as all, must be your internet service provider, so we all waste the ISP's time to come out and confirm they work. 30 minutes after the isp tested my system, at my site, ORBI blinked out, called ISP support, they could ping their router, connected directly to pc, yep, internet. An hour later ORBI blinks again, I decided to swap out for predecessor Linksys, 2 solid days of no interruption. Reinstalled ORBI, Blinked out in less than an hour. Yes Beamfrming enabled, yes MU-MIMO enabled, Backhaul topology on off, UPnP off blah blah blah, why should we have to do all this stuff, your product is supposed to work. That's what we paid for... fix your problem or give us our money back
I will preface this by saying I am not a tech so this could be totally out to lunch, but I noted today that the internet interruptions appear to occur when certain [DoS Attack: SYN/ACK Scan] from source: 144.76.16.7, port 8124, Wednesday, November 01, 2017 20:27:55
" appears in the log. They are not multiple simultaneous port scans, but this particular IP appears to scan once, several times per day.
