Friendlyx
Jun 27, 2017Tutor
Keep Loosing Internet Connection with my Orbi
I recently bought an orbi from amazon and i love it because it reaches throughout my whole house unlike my old router. However, i have noticed that i have dropped internet connections at times. For e...
JRBenning
Feb 08, 2018Tutor
I Too have noticed a degradation in maintaining connections after upgrading to firmware V2.1.2.18
My kids ask me daily to fix the WiFi at all hours of the night. I usually have to reboot the router (and not the modem). Since the modem seems fine and the stability of Orbi has only recently come into question… must assume it is this recent firmware. Do you have a fix or a way to revert to a more stable version. This is PAINFUL!
Streak2
Feb 08, 2018Master
What are your current settings for the following? Mine were unticked by default, try enabling beamforming and fast roaming if they are not already checked and disable them if they already are checked.
I also had a little instability after the firmware update but a factory reset and resync cleared things up.
| Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices | |
| Enable MU-MIMO | |
| Enable Fast Roaming |
- RvanDFeb 08, 2018Tutor
I moved the satellite to a different spot: problem solved, which still doesn't really solve the original problem. Now I wish my Genie app would work.
