sttorstein
Nov 21, 2019Follower
Keeps asking about admin password
When using the app it askes about password all the time. Now it doesnt accept the password anymore, but I have not changed it. Why cant it just work? I've read that I need to use a pc and to some adva...
Nov 21, 2019Guru - Experienced User
Are you referring to the Orbi app? If so, please post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- GreyBatNov 24, 2019Aspirant
I noticed this question was referred to the ORBI App board. For me this is actively a problem with the web UI. When my browser has a tab open to the router IP, I am constantly barraged with requests to re-enter userid (always "admin") and my password. What makes this more irritating is that the request appears as a popup window and it locks me out of all other tabs until I provide the information. This usually happens every 5 minutes or so, but sometimes the wait is longer thanks goodness. (Just got interrupted again while typing this reply!)
Oddly, most times, when I open a new browser tab (after I have closed it previously), I am often not asked for this information sometimes for several minutes. This behaviour occurs in V38 and V40. Not sure whether it did in previous releases, but I don't remember it being so invasive.
Would be interested to know if this is a known issue, or whether there are any fixes.
- FURRYe38Nov 25, 2019Guru - Experienced User
Be sure to clear all browser caches and then exit the browser. Then re-open the browser and enter back into the routers web page.
Try different browsers to compare.
Has a factory reset and setup from scratch been performed since last update?
GreyBat wrote:I noticed this question was referred to the ORBI App board. For me this is actively a problem with the web UI. When my browser has a tab open to the router IP, I am constantly barraged with requests to re-enter userid (always "admin") and my password. What makes this more irritating is that the request appears as a popup window and it locks me out of all other tabs until I provide the information. This usually happens every 5 minutes or so, but sometimes the wait is longer thanks goodness. (Just got interrupted again while typing this reply!)
- GreyBatNov 26, 2019Aspirant
Well, clearing the cache might have helped, but at the cost of losing all sign-in cookies! Seems to me it should not require such draconian measures!
And, no: I haven't done a factory reset!
And, again, I've been interrupted by the sign-in request while in the middle of typing this reply. So I don't think clearing the cache is the answer.
- CrimpOnNov 26, 2019Guru - Experienced User
GreyBat wrote:When my browser has a tab open to the router IP, I am constantly barraged with requests to re-enter userid (always "admin") and my password. What makes this more irritating is that the request appears as a popup window and it locks me out of all other tabs until I provide the information. This usually happens every 5 minutes or so, but sometimes the wait is longer thanks goodness. (Just got interrupted again while typing this reply!)
Oh, yes. This has been the way the Orbi web interface works for a long time, and is independent of which browser is being used. In my case, I can leave the Home Page up forever without being prompted. The "Attached Devices" page, however, pops up the login request about every five minutes and bugs the s**t out of me. I will be typing in another box, the damn screen pops up, and I type over "admin". So, not only do I have to hit the login button, but I also have to correct the mistaken typing.
Does this happen to you on every Orbi web screen, or only on some screens?
Well, it's reassuring to know someone else has the same issue!
I have installed Opera as a dedicated browser for the router, and, so far, even though I have been on the Attached Devices page for around 30 minutes or so I have had couple of prompts: "Your connection to this site is not private."
I would think it was pretty much private (though I am by no means an expert in such matters). Its a local IP address, and won't let a second device log in to it! This would seem to be unnecessary, isn't it?
