sttorstein
Nov 21, 2019Follower
Keeps asking about admin password
When using the app it askes about password all the time. Now it doesnt accept the password anymore, but I have not changed it. Why cant it just work? I've read that I need to use a pc and to some adva...
GreyBat
Nov 24, 2019Aspirant
I noticed this question was referred to the ORBI App board. For me this is actively a problem with the web UI. When my browser has a tab open to the router IP, I am constantly barraged with requests to re-enter userid (always "admin") and my password. What makes this more irritating is that the request appears as a popup window and it locks me out of all other tabs until I provide the information. This usually happens every 5 minutes or so, but sometimes the wait is longer thanks goodness. (Just got interrupted again while typing this reply!)
Oddly, most times, when I open a new browser tab (after I have closed it previously), I am often not asked for this information sometimes for several minutes. This behaviour occurs in V38 and V40. Not sure whether it did in previous releases, but I don't remember it being so invasive.
Would be interested to know if this is a known issue, or whether there are any fixes.
Nov 25, 2019Guru - Experienced User
Be sure to clear all browser caches and then exit the browser. Then re-open the browser and enter back into the routers web page.
Try different browsers to compare.
Has a factory reset and setup from scratch been performed since last update?
GreyBat wrote:I noticed this question was referred to the ORBI App board. For me this is actively a problem with the web UI. When my browser has a tab open to the router IP, I am constantly barraged with requests to re-enter userid (always "admin") and my password. What makes this more irritating is that the request appears as a popup window and it locks me out of all other tabs until I provide the information. This usually happens every 5 minutes or so, but sometimes the wait is longer thanks goodness. (Just got interrupted again while typing this reply!)
- GreyBatNov 26, 2019Aspirant
Well, clearing the cache might have helped, but at the cost of losing all sign-in cookies! Seems to me it should not require such draconian measures!
And, no: I haven't done a factory reset!
And, again, I've been interrupted by the sign-in request while in the middle of typing this reply. So I don't think clearing the cache is the answer.
- FURRYe38Nov 26, 2019Guru - Experienced User
Clearing the browser cache can also ensure the browser is correctly handling cookies or bad cookie or bad cached information that broswer now maybe in a bad state. Clearing this allow the browser to gather up the data and allows the user to ensure the sign in information is correct. Which this sounds like your browser state or cache is currently in. This is a normal use and resolution to browser issues. This only clears the cache and not saved PWs. You just can't rely on the data to be always accurate. Can be out of sync or in bad state and mis-handled by the browser. You seem to be the only one with this issue currently. I don't seen this with my browsers I use.
A factory reset should be performed on the RBR as a last resort.
Well, it seems to be happening for me in Firefox (brower of choice!) and Chrome! And I wouldn't mind so much if the sign-in request only appeared on the tab for the router UI. The problem is that, if I leave this tab open, I keep getting prompted - and forced back - when I am looking at other tabs...... like this one!
(BTW, I didn't mean to imply that my p/ws were lost. Just that I have to re-sign-in to all my saved sites, like gmail, guardian newspaper, etc.etc. Not to mention the loss of all my websudoku stats! Inconvenient!)
