bapechun
Nov 03, 2018Tutor
Kindle Paperwhite not found my Orbi RBR40
My Orbi RBR40 doesn't found at my Kindle Paperwhite even I have pressed the SYNC button, Any solution? Please advise, Thanks Eric
bapechun
Nov 03, 2018Tutor
Thanks, have a try to add into the network manually(WPA/WPA2), however the result is the same as is unable to connect to the Wi-Fi and asking me to contact Amazon Device Support. My other devices are no issue to connect the Wi-Fi and the same result even I have turned off my mobile and iPad connection
Nov 04, 2018Guru - Experienced User
What FW is currently loaded?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz.
Try Setting WPA to WPA and Auto, then try WPA2 and AES only.
Try disabling WMM temporarily as well.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
- bapechunNov 06, 2018Tutor
FW is 2.2.1.210
Channel is Auto
Encryption is WPA/WPA2
- FURRYe38Nov 06, 2018Guru - Experienced User
Try Setting WPA to Disable, then see if the Kindle connects, then set WPA and Auto, then try WPA2 and AES only.
bapechun wrote:
FW is 2.2.1.210
Channel is Auto
- JPCSNov 17, 2018Aspirant
My Kindle doesn't work with my Orbi neither.
bapechun wrote:
FW is 2.2.1.210
Channel is Auto
