bapechun
Nov 03, 2018Tutor
Kindle Paperwhite not found my Orbi RBR40
My Orbi RBR40 doesn't found at my Kindle Paperwhite even I have pressed the SYNC button, Any solution? Please advise, Thanks Eric
Feb 24, 2019Guru - Experienced User
What does the actual feature look like that your disabling in the routers web page?
Pttigui wrote:
Hello, I confirm that you can deactivate the SSID for the 5Ghz. This being said it does not mean it deactivates the emission of the 5Ghz signal, it just means that the router will signal to the devices that it does emit a 5Ghz signal. Do by doing so your Kindle will only detect the 2,4Ghz (since it will be the only SSID it will detect) and it will remind it in the future. I hope it's clearer.
Pttigui
Feb 24, 2019Guide
Hello, attach is a screenshot of the interface. You need to go in advanced > advanced setup > wireless > advanced wireless setup 5ghz. Here uncheck broadcast SSID and apply changes. Then connect your kindle to the network, go back to your orbit interface and reactivate broadcasting of the 5ghz SSID.
- FURRYe38Feb 24, 2019Guru - Experienced User
So you can disable the 5Ghz broadcast or at least temporarily keep devices from using it. This is nice. Hopefully this will help others.
