cheshbr
Apr 24, 2018Apprentice
Known Issues. Orbi Firmware V 2.1.4.10 update
Known Issue:
This one is published in the release notes for the 2.1.4.10 update
When user has two or more Orbi satellites connected to Orbi router using Ethernet backhaul connection, an Orbi sa...
tschroeder
Apr 28, 2018Guide
Good day,
The 2.1.4.10 update broke my wired backhaul. Everytime I plug in my Satellite to the ethernet backhaul - the Internet goes down. And I must reboot the modem and the Orbi Router. Is there a fix coming soon or can I re-install a previous firmware?
Tracy
Oceanwaves
May 11, 2018Star
tschroeder wrote:
Good day,
Tracy
I had the same problem with my RBK20 after updating to 2.1.4.10. I went back to 2.1.2.18 and everything was fine again. Then I found this post and did another try yesterday. Most important is time. I waited 5-10 minutes after each step and now the Orbis are running fine with FW 2.1.4.10 for 12+ hours.
