cheshbr
Apr 24, 2018Apprentice
Known Issues. Orbi Firmware V 2.1.4.10 update
Known Issue:
This one is published in the release notes for the 2.1.4.10 update
When user has two or more Orbi satellites connected to Orbi router using Ethernet backhaul connection, an Orbi sa...
May 23, 2018Guru - Experienced User
The Orbi is a router, not a modem. There will be or should be a modem or service box someplace, even for wireless P2P service. My uncle has this at his place. Has a motorola cable modem that interfaces there wireless ISP services with his router.
Do you know if the ISP is using DHCP or PPPoE connections with the ISP services?
When this happens do you have access to the routers web page at all via wireless or wired connections?
How big is your home? SqFt?
What is the distance between the router and satellite? Feet?
What channels are you using? Auto or manual?
Have you disabled MIMO, Daisy Chain and Fast Roaming and IPv6?
