cheshbr
Apr 25, 2018Apprentice
Known Issues. Orbi Firmware V 2.1.4.10 update
Known Issue:
This one is published in the release notes for the 2.1.4.10 update
When user has two or more Orbi satellites connected to Orbi router using Ethernet backhaul connection, an Orbi sa...
May 23, 2018Guru - Experienced User
Try factory reset and set up from scratch. Disable Daisy Chain. Add 1 satellite via wireless first. After the top LED turns BLUE and goes OFF. Connect the ethernet cable between the router and satellite. Wait 5 minutes. Top LED should turn BLUE.
Any network switches in between the router and satellite? If so, whats the Mfr and model#?
tschroeder wrote:
Disabled daisychain, restarted, waited, time in between starting each device, Reset all devices. Did not do factory reset. Still back haul does not work. Brings the whole Internet down.
tschroeder
May 24, 2018Guide
I will try a factory reset. But I don’t really have an hour or two to spend on this. It will have to wait till next week. I do have a switch in between. Netgear gb switch.
- cheshbrMay 24, 2018Apprentice
A Factory Reset is a drastic step, particularly if you have your Orbis in Router mode (Not AP mode), and you have set up reserved IP addresses in DHCP. Are you sure?
