cheshbr
Apr 24, 2018Apprentice
Known Issues. Orbi Firmware V 2.1.4.10 update
Known Issue:
This one is published in the release notes for the 2.1.4.10 update
When user has two or more Orbi satellites connected to Orbi router using Ethernet backhaul connection, an Orbi sa...
Jun 02, 2018Guru - Experienced User
The WAN port is the Internet port to the ISP modem.
Your modem must only handle 100mb and not 1000mb connection rates.
- chsalmonJun 03, 2018Apprentice
100 mb that's because i'm using a powerline to connect the orbi to the modem.
it's enough for what i want to do with ( a the place where is the router, there is not many device)
So the problem with the router could be hardware or because of the firmware ?
i think this is the firmware because with the V2.1.1.12 it works better, not great but better.
Strange that the satellite works like a charm (but with V2.1.1.12, i don't change it, it works too great )
ok, just done a last test.
My router was in ROUTER mode (no more AP)...to test if it's more stable...
i've just navigate to the web interface and bam, the router reboots !! i did nothgin else navigate in the admin interface :-(
is there a way to change the router ? with Netgear Waranty ? i'm living in France..
- FURRYe38Jun 03, 2018Guru - Experienced User
I recommend you phone contact your regional NG support office and get in contact there and let them know whats happening. Ask for an RMA as well.
