GregoryHD
Jan 02, 2018Aspirant
Known Samsung Issue
Has the "known Samsung issue" been fixed yet? I spent a day last month on the phone with various support people to finally get moved up to the next tier (after being put on hold for over 2 hours) to ...
DarrenM
Jan 04, 2018Sr. NETGEAR Moderator
There was a issue with samsung phones that was fixed with a update from samsung. Does your samsung phone have Android 8.0?
DarrenM
- GregoryHDJan 06, 2018Aspirant
I currently have a Galaxy S6 Edge. Which is at version 7.0. I'm not sure if it will get the upgrade or not to Oreo.
- GregoryHDFeb 01, 2018Aspirant
For the last month, I have been using the guest network... the only way to get my phone to stay connected to the wifi, which is not ideal. Even my Ring Doorbell was having issues and had to get a Ring Chime Pro to fix it.
