tandrew49
Dec 23, 2019Aspirant
lack of knowledge/understanding
greetings, I have an AT&T modem...trying to increase effectiveness in a fairly large home. I have plugged in three orbi's. One to the modem (RBR40) and one in an outlet about 15 feet away (RBS40) ...
CrimpOn
Dec 23, 2019Guru - Experienced User
The Orbi that was purchased used (which I do, also) probably was originally part of an Orbi package and set up with a different WiFi name. The trick is to do a "factory reset" on this satellite (using the famous paperclip) and then "sync" it to the Orbi router.
Factory reset involves sticking the end of a paperclip into the tiny "Reset" hole on the back of the satellite close to the power plug and holding it until the power LED turns amber and then begins to blink. Can take 15-20 seconds. Once it blinks, pull out the paperclip and the satellite will be reset. Here is a link to doing a sync:
https://www.youtube.com/watch?v=ePZSc7vnRlQ
tandrew49
I can get it reset, but cannot get it to sync.
when syncing the satellites are they supposed to be close to each other and then moved to locations throughout the house, or are they supposed to be synced from the location they will be operating at. none of these are really far form each other...RBR at the at&t modem, RBS40 only about 10 feet away, and RBS 20 about another 15 feet on the other side of the wall.
one more question, after syncing how can I tell if they are working, or keep working, individually. The RBS40 is syncing but not the other.
- tandrew49Dec 23, 2019Aspirant
sorry, one more thing, the ring light on the rbs20 never changes color, just flashes white the whole time
sorry to be so erratic here...i did locate the app on my phone so I can tell which ones are working and I am only getting signal from router and 1 sattelite
moved the rbs 20 closer to router but still not syncing...is the designation '20' significant. I do notice that sattelite is a lot smaller than the RBS 40
- CrimpOnDec 23, 2019Guru - Experienced User
tandrew49 wrote:when syncing the satellites are they supposed to be close to each other and then moved to locations throughout the house, or are they supposed to be synced from the location they will be operating at. none of these are really far form each other...RBR at the at&t modem, RBS40 only about 10 feet away, and RBS 20 about another 15 feet on the other side of the wall.
My practice has been to do the original sync with the devices in the same room with the router. At my age, dashing up and down stairs to get the 'sync' button pressed in time and observe the ring lights is a recipe for disaster. I prefer to have everything in one place.
Having a satellite 10ft from the router is sort of a 'waste'. The satellite will have a great backhaul connection, but the WiFi coverage of router and satellite will overlap almost completely overlap. Most people find that someplace between 20 and 30 feet is a "sweet spot" where the backhaul remains strong and the area covered is large enough. Netgear's only advice on where to place a satellite is "if the top ring turns amber, consider moving the satellite closer."
EVERY Orbi satellite works with every router. Lots of people mix them successfully.
If pressing the sync buttons isn't working with the RBS20, you can try using the Orbi web interface which has an "Add a satellite" option on the Home Page.
