cuidi
Dec 02, 2016Aspirant
Lack of Speed using RBK53 AC3000 Tri-band WiFi system
I have about 115 GB download and 10 GB upload and about 35 GB download and 10 GB upload on Wi-Fi. Installed the Orbi High Performance AC 3000 tri-band and the WiFi has dropped to 25 GB download and ...
peteytesting
Dec 02, 2016Hero
cuidi wrote:I have about 115 GB download and 10 GB upload and about 35 GB download and 10 GB upload on Wi-Fi. Installed the Orbi High Performance AC 3000 tri-band and the WiFi has dropped to 25 GB download and holding 10 GB upload. Very disappointed! Any advice?
you mean 115Mbps and 10Mbps right ?
with what device where you getting that on router wise
as i have 100Mbps down and 40Mbps up internet wise and i can get that on any device anywhere in my home as long as im connected to the 5 gig band of the orbi and my device is also connected to 5 gig
you may want to check the device you are using hasnt connected to the 2.4 gig band
- cuidiDec 03, 2016Aspirant
You are correct, it is Mbps not GB's, sorry.
Last night I left the Orbi running and this morning was supprised when I ran a speed test. My MacBook Pro using the Orbi's wi-fi was getting 114/12Mbps! I switched to the Arris router, supplied by Spectrum, using 5 gig wi-fi and was getting 60/12Mbps. I then when to my Mac desktop which is hardwired and was getting only 38/12Mbps??? I switched to wi-fi using the Orbi's wi-fi and was getting 115/12Mbps.
This makes no sense to me?? I am totally confused now!
