cuidi
Dec 02, 2016Aspirant
Lack of Speed using RBK53 AC3000 Tri-band WiFi system
I have about 115 GB download and 10 GB upload and about 35 GB download and 10 GB upload on Wi-Fi. Installed the Orbi High Performance AC 3000 tri-band and the WiFi has dropped to 25 GB download and ...
peteytesting
Dec 02, 2016Hero
cuidi wrote:I have about 115 GB download and 10 GB upload and about 35 GB download and 10 GB upload on Wi-Fi. Installed the Orbi High Performance AC 3000 tri-band and the WiFi has dropped to 25 GB download and holding 10 GB upload. Very disappointed! Any advice?
you mean 115Mbps and 10Mbps right ?
with what device where you getting that on router wise
as i have 100Mbps down and 40Mbps up internet wise and i can get that on any device anywhere in my home as long as im connected to the 5 gig band of the orbi and my device is also connected to 5 gig
you may want to check the device you are using hasnt connected to the 2.4 gig band
cuidi
Dec 03, 2016Aspirant
You are correct, it is Mbps not GB's, sorry.
Last night I left the Orbi running and this morning was supprised when I ran a speed test. My MacBook Pro using the Orbi's wi-fi was getting 114/12Mbps! I switched to the Arris router, supplied by Spectrum, using 5 gig wi-fi and was getting 60/12Mbps. I then when to my Mac desktop which is hardwired and was getting only 38/12Mbps??? I switched to wi-fi using the Orbi's wi-fi and was getting 115/12Mbps.
This makes no sense to me?? I am totally confused now!
