Kbomb20
May 13, 2019Aspirant
Lag spikes while gaming using Orbi RBK50 satellite
I have an OrbiRBR50 system and a PS4 pro connected to the satellite on a separate floor below the main router. I have wired connected the PS4 to the satellite router while the satellite is wirelessly...
CrimpOn
May 13, 2019Guru - Experienced User
Kbomb20 wrote:
While gaming, I experience really bad lag spikes via this setup even though my download and upload speeds are very good. While troubleshooting the lag, I tried several configurations but one removed my lag spikes. I disconnected from the satellite and had the PS4 connect directly to the main router which is one floor above the PS4. The download and upload speeds are slower but the gaming connection is constant and the ping is faster. Is there something wrong with my satellite or is this behavior expected?
You are not the first to report this. My impression is that your experience is typical. A wired connection will ALWAYS be (1) faster and (2) more consistent than a WiFi connection, and it doesn't matter whether the WiFi is to the device or between the Orbi router and satellite. I ran a bunch of 5,000 ping tests connecting various devices to the router and satellite where the satellite was connected both wired and over the 5G WiFi backhaul. In every case, with every device, responses where there was any WiFi took longer on average and about 2% of the responses were quite a bit longer. Most of our wired connections these days involve point-to-point switches where there are no collisions. WiFi collisions may simply result in a slower and less consistent communication.
Just to be clear, I was using 60 byte ping packets. Average ping was from 2ms to 5ms, and the longest ping response was only 112ms (about 1/10th of a second). Are PS4 gaming packets longer? If they are, that might lead to more variability.
