cmeyer1213
Nov 28, 2017Follower
Lag spikes with RBK50
I recently got the RBK50 Orbi setup and I would say I love it except Im getting random lag spikes in most of my games, Ill have low ping and then it will spike anywhere from 100-300. Normally I would...
DarrenM
Nov 29, 2017Sr. NETGEAR Moderator
You would have to look at the logs of the gateway for when these spikes happen and see if it the internet or if its the router that is causing the issue. Also you may want to remove the network switch see if that may be causing a issue.
DarrenM
