Honjebee
Dec 27, 2020Aspirant
Lan Connection Dropping
Hi Over the last month or so, the LAN connection to the satellite have been dropping briefly (perhaps 2 or 3 times per day and the connection will come back within a few seconds). I've confirmed...
- Dec 27, 2020
Ar
Honjebee wrote:Hi
..I've now downgraded the satellite to 2.5.1.16 which I believe it would have been running back when this didn't occur and will continue to monitor but was hoping anyone might have come across this. I've not found any community posts about this kind of thing that have occurred any time recently....
Is it behaving OK on 2.5.1.16?
If the only change to firmware makes the issue appear/dissappear, then thats the prime suspect.
There's a 2.7.1.60 on the download page. And an even newer one that some people are able to get from their router setup web page (or Orbi app). Do a factory reset after changing the firmware and set up the router and satellite from scratch.
(I am not using the ethernet ports on my satellite, so I cannot comment on this happening for my setup.)
Honjebee
I did a manual reset (pin in the hole) of the RBS50 but not the RBR50 itself however I'm only having issue with the satellite acting essentially as a LAN switch.
They sit around 25ft apart with a floor and wall between them but the connection between them has always been pretty solid as has any devices connecting wireless (to either). Neighbours are far enough away as to not cause any interference.
Dec 27, 2020Guru - Experienced User
When doing a factory reset, BOTH RBS AND RBR should be reset.
Hopefully v16 will be ok then.
