Rogier_L's avatar
Rogier_L
Lan connections not working
Hello netgear community, I just switched from an old D-link router/WiFi modem to the Orbi RBR50 with 2 satelites. The WiFi works perfect but the devices that use to work with LAN cable do not make co...
  • ekhalil's avatar
    ekhalil
    Sep 23, 2019
    Rogier_L wrote:
    I just found out that the router/modem from my internet provider can be switched into Bridge-modus. With this modus;
    - WiFi is switched off
    - DHCP server and NAT settings are cancelled
    - Firewall is switched off
    - LAN connections 2-4 are blocked
    Should I do this? Or make Orbi the accespoint?
    It depends on the router capability of the ISP router compared to Orbi. It's your choice.
    I would bridge the ISP mode and keep Orbi in Router Mode.
