Rogier_L
Sep 22, 2019Aspirant
Lan connections not working
Hello netgear community, I just switched from an old D-link router/WiFi modem to the Orbi RBR50 with 2 satelites. The WiFi works perfect but the devices that use to work with LAN cable do not make co...
- Sep 23, 2019
Rogier_L wrote:
I just found out that the router/modem from my internet provider can be switched into Bridge-modus. With this modus;
- WiFi is switched off
- DHCP server and NAT settings are cancelled
- Firewall is switched off
- LAN connections 2-4 are blocked
Should I do this? Or make Orbi the accespoint?It depends on the router capability of the ISP router compared to Orbi. It's your choice.
I would bridge the ISP mode and keep Orbi in Router Mode.
Rogier_L
Sep 23, 2019Aspirant
ekhalil
Sep 23, 2019Master
- Rogier_LSep 26, 2019AspirantWith the new modem from my ISP switched into bridge-mode everything works perfect 👍🏻
