Hawkmoth
Aug 16, 2018Star
LAN Connectivity Failure from Wireless Diagnostics (macOS)
During some aggravating trouble shooting while setting up a new Orbi system to address the scanner of our Brother multi-function printer, I ran the Mac Wireless Diagnoistics app. It renurned (and sti...
- Aug 17, 2018
If things are working with the Orbi though, I wouldn't worry about it too much.
Aug 17, 2018Guru - Experienced User
So does the Mac diagnostic utility pass if you connect the Mac to the base router? I presume it should.
Does the Mac work ok when connected to the satellite?
It maybe that the apps doesn't know how to handle a connecting thru a wireless mesh system.
Hawkmoth
Aug 17, 2018Star
The LAN Connectivity Failure persists if I turn off the satellite. The rest of the message about this suggests restarting the router. Doing that also does not eliminate the reported failure.
