Hawkmoth
Aug 16, 2018Star
LAN Connectivity Failure from Wireless Diagnostics (macOS)
During some aggravating trouble shooting while setting up a new Orbi system to address the scanner of our Brother multi-function printer, I ran the Mac Wireless Diagnoistics app. It renurned (and sti...
- Aug 17, 2018
If things are working with the Orbi though, I wouldn't worry about it too much.
Aug 17, 2018Guru - Experienced User
And does this happen if you disable wifi on the Mac and connect it via Lan cable to the back of the router?
