Hawkmoth
Aug 16, 2018Star
LAN Connectivity Failure from Wireless Diagnostics (macOS)
During some aggravating trouble shooting while setting up a new Orbi system to address the scanner of our Brother multi-function printer, I ran the Mac Wireless Diagnoistics app. It renurned (and sti...
- Aug 17, 2018
If things are working with the Orbi though, I wouldn't worry about it too much.
Aug 17, 2018Guru - Experienced User
This is a temp test. However try with the satellite. I presume you may see the same message.
Hawkmoth
Aug 17, 2018Star
Seems problematic, since the application itself is Wireless Diagnostics, doesn't it. Not LAN diagnostics. But will try it when I get a chance. Can't right now. Thanks for the suggestions.
