Hawkmoth
Aug 16, 2018Star
LAN Connectivity Failure from Wireless Diagnostics (macOS)
During some aggravating trouble shooting while setting up a new Orbi system to address the scanner of our Brother multi-function printer, I ran the Mac Wireless Diagnoistics app. It renurned (and sti...
- Aug 17, 2018
If things are working with the Orbi though, I wouldn't worry about it too much.
Aug 17, 2018Guru - Experienced User
Ok. I presume this is how the app works. Nothing to be too bothered by. You might ask Apple support on this and how it supposed to work.
Hawkmoth
Aug 17, 2018Star
I did contact Apple support first. The tech I talked to was interested, but also did not understand what the message means. I declined her offer to elevate to a more senior tech. It's a puzzle, but not a functional matter at this point.
- FURRYe38Aug 17, 2018Guru - Experienced User
Ya, well, it's there product, they should know about it.:smileyfrustrated:
Good Luck. :smileywink:
- HawkmothAug 17, 2018Star
I agree - Apple should know what their message means. I presume someone there does, but I'm not sure how persistent I want to be to get to the one who is in the know. I was hoping posting here might work without too much fuss.
