awabel
Jun 17, 2021Aspirant
LAN dropping Connection to a TV in Mirror Cast periodically
I am having issues when mirror casting from my Lenovo X1 Carbon to a 2 year old Samsung Smart TV. I am able to ge the connection initially and then at some random amount of time the connection will ...
CrimpOn
Jun 17, 2021Guru - Experienced User
awabel wrote:I am having issues when mirror casting from my Lenovo X1 Carbon to a 2 year old Samsung Smart TV.
There appear to be several methods of mirroring a laptop screen to a tv. Could you describe which of these methods is being used:
https://www.lenovo.com/us/en/faqs/laptop-faqs/connect-laptop-to-tv/
awabel
I'm using the screen casting tool built into Windows 10.
- CrimpOnJun 17, 2021Guru - Experienced User
awabel wrote:I'm using the screen casting tool built into Windows 10.
The reason I asked is that Lenovo article says this about the screen casting capability built into Windows 10::
The beauty of technologies such as Miracast is that they don't rely on your home/office wireless network. Instead, signals are transmitted via Wi-Fi Direct, which has a shorter signal range but enables device-to-device streaming without a central router.
This would seem to indicate that the issue has nothing to do with the home WiFi network (Orbi).
The Lenovo X1 Carbon has an HDMI port, which would appear to indicate that it could be connected directly to the tv.
- awabelJun 17, 2021Aspirant
Of course, it can be directly connected but I already have a monitor connected. This additional TV is for presentation to my clients.
