awabel
Jun 17, 2021Aspirant
LAN dropping Connection to a TV in Mirror Cast periodically
I am having issues when mirror casting from my Lenovo X1 Carbon to a 2 year old Samsung Smart TV. I am able to ge the connection initially and then at some random amount of time the connection will ...
Jun 17, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Contact the mfr of this Mirror Casting to see if there is any known information regarding problems with this TV or Lenovo laptop.
awabel
None of those changes solved the problem.
