dpass83
Feb 11, 2017Tutor
LAN ports stopped working
Out of no where, my LAN ports stopped working both on router and sat. I have rebooted and reset but does not fix. After a reboot, the ports will work for about two minutes but then anything connected ...
DarrenM
Feb 13, 2017Sr. NETGEAR Moderator
Hello dpass83
Have you done a factory reset by holding the reset button for 10 seconds? Also have you updated to the latest firmware?
DarrenM
