dpass83
Feb 11, 2017Tutor
LAN ports stopped working
Out of no where, my LAN ports stopped working both on router and sat. I have rebooted and reset but does not fix. After a reboot, the ports will work for about two minutes but then anything connected ...
dpass83
Feb 13, 2017Tutor
yes to both.
DarrenM
Feb 13, 2017Sr. NETGEAR Moderator
Hello dpass83
You may want to contact support if there is a hardware issue with your unit.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
