dpass83
Feb 11, 2017Tutor
LAN ports stopped working
Out of no where, my LAN ports stopped working both on router and sat. I have rebooted and reset but does not fix. After a reboot, the ports will work for about two minutes but then anything connected ...
DarrenM
Feb 27, 2017Sr. NETGEAR Moderator
Hello MollyDg
Have you factory reset the unit and updated to the latest Firmware? If so you may want to contact support if this is still happening.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- MollyDgMar 20, 2017Tutor
Hi DarrenM,
I tried resetting and do have the latest Firmware. Like I said works great wirelessly. But when I plug in something to the LAN port, stops working, turns magenta. Tried calling support and they just told me the same thing to update and reset. Any other ideas???
- DarrenMMar 23, 2017Sr. NETGEAR Moderator
I would call back to support and tell them none of those solutions worked could be a hardware issue.
DarrenM
