dpass83
Feb 11, 2017Tutor
LAN ports stopped working
Out of no where, my LAN ports stopped working both on router and sat. I have rebooted and reset but does not fix. After a reboot, the ports will work for about two minutes but then anything connected ...
MollyDg
Mar 20, 2017Tutor
Hi DarrenM,
I tried resetting and do have the latest Firmware. Like I said works great wirelessly. But when I plug in something to the LAN port, stops working, turns magenta. Tried calling support and they just told me the same thing to update and reset. Any other ideas???
DarrenM
Mar 23, 2017Sr. NETGEAR Moderator
I would call back to support and tell them none of those solutions worked could be a hardware issue.
DarrenM
