dpass83
Feb 11, 2017Tutor
LAN ports stopped working
Out of no where, my LAN ports stopped working both on router and sat. I have rebooted and reset but does not fix. After a reboot, the ports will work for about two minutes but then anything connected ...
ollewis
Jan 21, 2018Guide
Had a power failure and then ethernet ports stopped working on the router.
I read online someone unplugged their ethernet switch (hub?) that was wired to the Orbi.
I tried that, unplugged the hub.
That did it for me. I then plugged the hub back in and now all is fine
rosstradamus
Jan 27, 2018Initiate
Unplugging the switch worked for me too. Glad this got resolved!
- SeanSeahMar 17, 2018Aspirant
Just set up a new RBK. Wireless works fine but my 3 ports are working when plugged directly into the router. However once i plug it into a long cable it no longer works. Was working when I initially set it up. I have already done a reset!
- Brain29Mar 17, 2018Apprentice
My lan and wifi ports stop working once a day seems to be no resolution talking to support
