dchaudron
Feb 11, 2021Aspirant
laptop connecting to 2.4G but not 5
I have a Dell laptop. How do I force it to use 5. nstead of 2.4? It's comptabile and other devices, such as my Android phone, automatically do this. 2.4 and 5 SSID's are already turned off.
Feb 11, 2021Guru - Experienced User
Be sure your wifi adapter drivers are updated.
Check with the mfr of this adapter to see if there is any kind of adapter UI configuration to make it connect to only 5Ghz signals. Some adapters have this feature.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
dchaudron wrote:I have a Dell laptop. How do I force it to use 5. nstead of 2.4? It's comptabile and other devices, such as my Android phone, automatically do this.
- dchaudronFeb 11, 2021Aspirant
I have the latest driver for the wireless adapter, a Intel(R) Dual Band Wireless-AC 3165. I looked, but I couldn't find any option to limit it to 5.
I looked under advanced, advanced settings, but I couldn't find the RBR setting you mentioned. (And I don't know what RBR is).
Thanks for your help.
- FURRYe38Feb 11, 2021Guru - Experienced User
RBR is the Orbi router unit. Log into it's web page and make the adjustments there.
i reduced the 2.4 radio to 25%, and then it connected o 5. Now I can test. Thanks!
I found the radio strength options, and reduced the 2.4 to 50%. The Dell is still connected to 2.4
- Mikey94025Feb 11, 2021Hero
dchaudron wrote:I have the latest driver for the wireless adapter, a Intel(R) Dual Band Wireless-AC 3165. I looked, but I couldn't find any option to limit it to 5.
Try this:
- Win-S, search for "network connections"
- Right-click your Wi-Fi connection and select Properties
- Press Configure for your Intel adapter
- In the Advanced tab, do you see a property like "802.11a/b/g Wireless Mode"? My Intel Wireless-AC 9560 adapter lets me change that property to 5Ghz instead of Dual Band.
https://www.intel.com/content/www/us/en/support/articles/000005585/network-and-i-o/wireless.html
- CrimpOnFeb 11, 2021Guru - Experienced User
My Intel AC 7265 adapter also has a setting for Preferred Band (2.4G or 5G). What Fun!
(This is in a Lenovo laptop that is several years old.)
