LewBob's avatar
LewBob
Laptop keeps hooking to satellite instead of the router in the same room. RBK53 AC3000
I have the original Orbi three piece set up. I have the latest firmware. I have been frustrated with widely varying speed on a laptop that is in the same room as the router, though about 30 feet away...
  • FURRYe38's avatar
    Sep 05, 2021
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    LewBob wrote:
    I have the original Orbi three piece set up. I have the latest firmware. I have been frustrated with widely varying speed on a laptop that is in the same room as the router, though about 30 feet away. I have a satellite in my living room. There are two walls and furnace venting in the between the laptop and that satellite. I finally figured out how to use the browser connection to see how everything is connected. The laptop keeps connecting to the living room satellite and sometimes goes to 2.4G because the 5 G signal is so weak. A recent Forbes review of the wifi 6 AX-4200 reported the same problem with the new system. A Netgear spokesman had no solution.
    "Then there were the oddities I discovered in testing. The printer in my ground-floor office deciding it would connect to the satellite in the loft bedroom two floors away instead of the router only 5m away. Amazon Echo devices in that loft bedroom connecting to the router, despite being in the same room as the satellite."
    Any ideas?
