Tozmachine
Nov 27, 2019Tutor
Laptop not accessible to local network
Hello I need your help with my orbi system: I have a laptop connected in ethernet to my internet box.IP address is 192.168.X.X. Let's name this laptop A I've setup wifi through Orbi I've a l...
- Nov 27, 2019
Tozmachine wrote:I've just tried to connect the other laptop in wifi and I have the same issue.
Now I've both with IP Address: 10.0.0.X
Strange it seems that orbi lock ping and remote on network.
Perhaps I am not understanding. Both laptops are connected to the Orbi WiFi and both now have addresses 10.0.0.x.
A can ping B, but B cannot ping A? This is still the case?
Windows 10 by default does not respond to ping (ICMP requests). Perhaps one of the laptops is allowing ping and the other is not?
https://tunecomp.net/allow-incoming-ping-echo-request-without-disabling-windows-10-firewall/
CrimpOn
Nov 27, 2019Guru - Experienced User
This is a consequence of having two routers (Google "Double-NAT"). There are two easy solutions:
- Connect all devices to the Orbi, with nothing connected to the internet box.
- Put the Orbi into Access Point (AP) mode using the Orbi web interface, Advanced Tab->Advanced Setup->Router/AP Mode
- TozmachineNov 27, 2019Tutor
THanks of you help
Thanks of your help
- CrimpOnNov 27, 2019Guru - Experienced User
You're right, I didn't update the status but now (as they are both on Orbi now) I'm no more able to ping and doing RDP on both side.
