Tozmachine
Nov 27, 2019Tutor
Laptop not accessible to local network
Hello I need your help with my orbi system: I have a laptop connected in ethernet to my internet box.IP address is 192.168.X.X. Let's name this laptop A I've setup wifi through Orbi I've a l...
- Nov 27, 2019
Tozmachine wrote:I've just tried to connect the other laptop in wifi and I have the same issue.
Now I've both with IP Address: 10.0.0.X
Strange it seems that orbi lock ping and remote on network.
Perhaps I am not understanding. Both laptops are connected to the Orbi WiFi and both now have addresses 10.0.0.x.
A can ping B, but B cannot ping A? This is still the case?
Windows 10 by default does not respond to ping (ICMP requests). Perhaps one of the laptops is allowing ping and the other is not?
https://tunecomp.net/allow-incoming-ping-echo-request-without-disabling-windows-10-firewall/
Nov 27, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Tozmachine wrote:Hello
- I have a laptop connected in ethernet to my internet box.IP address is 192.168.X.X. Let's name this laptop A
- I've setup wifi through Orbi
- I've a laptop connected to the wifi with IP adress 10.0.0.X. Let's name it Laptop B
Problem
I'm able to ping B from A and able to do RDP.
I'm not able to ping and launching remote from A to B.
NB: the two laptops are on Windows 10 Enterprise, Network is parameter as "Private", RDP is allowed in the parameter.
Thanks of your help !
- TozmachineNov 27, 2019Tutor
Thanks of your feedback FURRYe38
"What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?"
Yes it's built in router.
Just before trying to change in bridge mode. Are you sure I can have impact of this ISP modem between 2 laptops connected in wifi on orbi ? They are now on the same orbi network (10.0.0.X) I understand now double-nat problem and it seems that it's between 2 devices connected on different router, isn't it ?
THanks
- FURRYe38Nov 27, 2019Guru - Experienced User
Yes, if the ISP modems is working and a router and wifi, then you laptops maybe connecting to the modem as well. Since they are now seemingly connected to the Orbi system, there getting a 10.x.x.x IP address, this tells us that the Orbi detected the router at the modem, the modems IP address was probably 192.168.1.1 and this would cause a conflict with the Orbi default IP address, so the Orbi changed it's own IP address pool to something different, i.e. 10.x.x.x.
So the modem needs to be bridged fully if possible. I would ask your ISP about bridging the modem if you don't know how to, or if the modem doesn't support bridging, review the #2 option. WiFi on the ISP modem needs to be disabled regardless so your laptops don't get confused and only connect to the Orbis Wifi, thus you don't get confused. :smileywink:
Tozmachine wrote:Thanks of your feedback FURRYe38
THanks
