Peterwg
Sep 06, 2018Follower
Laptop stopped detecting Orbi RBK50
I have several laptops, tablets, TVs, mobile phones etc connected to my Orbi RBK50.
One of the laptops now does not detect the Orbi. I have had the laptop examined by the local specialist and he h...
Sep 06, 2018Guru - Experienced User
What FW is currently loaded?
Does the LT see the wifi SSID name or just won't connect to it?
Be sure that the IP address is a reserved IP address set ON the router for the Laptop. There many two IPs needed, one for the Wireless connection and one for the wired connection.What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try setting WPA to disable temporarily. Does the LT connect then? If so, go back and test WPA and TPIK and test. Then try WPA2 and AES only.
