Gibbous
Jan 17, 2020Tutor
Laptop takes 10 minutes to reconnect to Orbi Router
Hi All, whenever I leave my home network with my Laptop to use it away from the home, as soon as I return it takes almost 10 minutes to get an internet connection. Also, occasionally with my iPa...
Jan 17, 2020Guru - Experienced User
What is the Mfr and model# of this laptop.
What is the Mfr and model# of the laptops wifi adapter card?
If other devices connect immediately and the laptop doesn't, this would be laptop issue, not Orbi. Ensure the laptops wifi and networking adapter drivers are up to date.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Gibbous
Jan 17, 2020Tutor
Thanks for the Tips!
