JohnB92
Jun 27, 2019Follower
Laptop Will Not Connect to 5Ghz Orbi Even Though Laptop is Compatible
My laptop is 5 ghz compatible (I know this). However in the app it will only connect to 2.4ghz which results in terribly slow speeds. Need help.
Jun 28, 2019Guru - Experienced User
You can however disable the 2.4Ghz SSID from being seen temporarily by setup devices. Under Advanced Tab/Advanced Settings/Wireless Settings. Take the check mark out of the Enable SSID (2.4G) box. This will hide 2.4Ghz SSID support for any 2.4Ghz supporting setup devices and force them to connect to the 5Ghz SSID frequency. Does the laptop connect to the 5Ghz radio then?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
JohnB92 wrote:My laptop is 5 ghz compatible (I know this). However in the app it will only connect to 2.4ghz which results in terribly slow speeds. Need help.
